Help with prime 95
29 May 2007
Hi all, i decided to have ago with overclocking and did, any way I'm just wondering about prime 95 when i use blend test, it only maxes the CPU out @ 50% should it not be 100? thanks in advance :)
Dual core?
If so you'll need to run two instances of Prime and assign one to each core. Or download Orthos or the new version of Prime (25.2 I think it is).
Jokester
Means something about your overclock isn't stable. Could be RAM, CPU or chipset depending on settings and what test Prime was running.
Jokester
