Help with problem on
17 Oct 2006
Aviemore, Cairngorms, Scottish Highlands
I have a renault megane and for about a year mow and again I would here a funny noise from the underside of the car but had it on a ramp and could not find it, over the next few months it has got worse and tonight after more search I have found what is loose. Its the the hoop with the teeth in the picture. Anyone shed any light what it is and why its lose. Is it safe to drive etc. :confused: should say its just behind the wheel on the ball joint. I'm sure it not a wheel bearing as I had it done not that long ago.
It shouldn't be loose, I would have thought having it welded in place again would be the only way to secure it, if not you will have to buy a new CV joint, although with many French cars you can only buy complete driveshafts.
That ring is what the ABS sensors picks up (though magnetic pulses iirc) when the ring stops spinning it assumes the wheels have locked up and the ABS will kick in. If the ring has moved out of place, the sensor wont be picking it up which is why you have the ABS warning light on.
What year megane? Trouble is as the ABS light is on if its got EBD then your brake balance will be all over the shop and greatly reduce the capability of the brakes as it just reverts to a 50/50 split.
No you can get just the rings, they'll probably try to sell you a driveshaft though. If you can get me your oval plate details then i'll be able to find a part number/price for you.
Apparently they're very delicate and hard to replace without cracking them.
Have a look on ebay for the whole CV joint, probably only be about £25-£30
Can I just cut the old one off to stop the noise ;), I know I will have no ABS but this is not a major problem till I get it fixed. Also why did this not get picked up by the renualt dealer when they done the check on the breaks or the MOT :mad:
Call em up and ask them
http://cgi.ebay.co.uk/CV-Joint-Kit-...VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
there you go! £15 for a brand new CV joint. Get someone to fit it for about £40 and you've fixed your problem for only £55. Bargain!
I would have your CV boot (the black rubber part) checked too, it looks like some grease has escaped, you might have a small split in, I would expect that to be changed when the joint is done anyway.
