help with psu
21 Dec 2011
hey, at the moment i have a cheap non modular 650watt CiT, nearer to march im upgrading my pc quite a lot and i dont really trust the psu, it also makes a lot of noise and sounds like the fan is about to fail at some points.
can anyone recommend a modular psu that is reliable, reasonably length'd cables, black with black cables, within a reasonable price range.
my specs are as off below, although upgrading to a asrock z68 extreme 3 gen 3 motherboard and a i5 2500k
edit: i would also preferably like it to have 2x 6pin connectors for my 6870, at the moment im using molex's
tbh i would rather have separate sata and molex cables like that ocuk one, so i dont have spare ones lying about and having to hide them, also i would have more flexibility.
i dont think that has x2 6pin pci-e connectors which i really want, i think in the end im just going to chip in that extrea bucks and get the xfx
