Help with "Rage" performance
30 Mar 2013
So after hearing about all the problems with rage I decided to download a torrent version to see if it would run ok on my system and it ran fine maxed out at 60fps with the odd dip so I purchased it on steam. the legal steam version runs like utter crap, dropping into the low 20s. Any ideas on what could be the problem
[email protected]
Xfx 7850 2gb
8gb corsair vengeance at 1600 MHz
Edit: just validated the integrity of game cache and it gave me this "1 files failed to download and will be required" gives no clue as to what the file is.
Gfx card memory? There is a setting that absolutely rapes fps, think it puts the textures up to 8k resolution or 4k can't remember but it might not be that cause when I had the game installed I kept getting weird ass spikes which I couldn't fix after trying loads of fixes.
There's something to do with caching which might help, try googling it.
