help with raid 0 i think
go in to the bios, enable raid, reboot, look for raid setup e.g f8
create your raid 0 . all good to go:)
warning drives will be formatted.
Assuming you've got your drives hooked upto the appropriate Sata ports.
Boot into bios, look for Sata controller options and set them to raid, save and reboot.
Boot into your boards raid controller (it's usually something like CTRL + R), you'll see a prompt anyway. Create your raid array by following the onscreen instructions. Save and exit.
Now install windows via the usual method, you should see one larger drive I stead of your two smaller ones.
That's basically the gist, keep a laptop handy so you can google stuff if you run into any problems.
