Help with rando picture script please
25 Oct 2002
Derbyshire
Help with random picture script please
I've found a script to change a picture to any from a set folder.
http://ccgi.theblue.plus.com/cpg1414/albums/wpw-20080101/random.php
What i'd like it to do is pick only large pictures. The album software i've used creates files such as:-
and the origional file:-
Can the script be changed to ignore 'thumb_' & and 'normal_'
Code:
<?php
By Matt Mullenweg > http://photomatt.net
Inspired by Dan Benjamin > http://hiveware.com/imagerotator.php
Latest version always at:
http://photomatt.net/scripts/randomimage
*/// Make this the relative path to the images, like "../img" or "random/images/".
// If the images are in the same directory, leave it blank.
$folder = '';
// Space seperated list of extensions, you probably won't have to change this.
$exts = 'jpg jpeg png gif';
$files = array(); $i = -1; // Initialize some variables
if ('' == $folder) $folder = './';
$handle = opendir($folder);
$exts = explode(' ', $exts);
while (false !== ($file = readdir($handle))) {
foreach($exts as $ext) { // for each extension check the extension
if (preg_match('/\.'.$ext.'$/i', $file, $test)) { // faster than ereg, case insensitive
$files[] = $file; // it's good
++$i;
closedir($handle); // We're not using it anymore
mt_srand((double)microtime()*1000000); // seed for PHP < 4.2
$rand = mt_rand(0, $i); // $i was incremented as we went along
header('Location: '.$folder.$files[$rand]); // Voila!
Code:
<?php
$files = glob('{*.PNG,*.png,*.JPG,*.jpg,*.GIF,*.gif}', GLOB_BRACE);
do {
    $file = $files[array_rand($files)];
} while ( preg_match('#(_thumb|_normal)#i', $file) > 0 );
readfile($file);
Code:
<?php
do {
readfile($file);
Code:
<?php
do {
} while ( preg_match('#[COLOR="Yellow"]^(thumb_|normal_)[/COLOR]#i', $file) > 0 );
[COLOR="Yellow"]header('Content-type: ' . mime_content_type($file) . "\r\n");[/COLOR]
readfile($file);
Code:
<?php
do {
readfile($file);
pedantry and nitpicking of the highest and most annoying order
Ok, I've got it to work.
Can i add this to a html page so it shows the pic in the middle?
Can someone post an example I can mod :)
Thanks in advance!
You can use the PHP script in place of an image, just right click my sig and you'll see it refers to a PHP file and not an image directly. For Example:
Code:
[b][i]...[/i][/b]
<img src="./random.php" alt="" />
[b][i]...[/i][/b]
