help with raptor drive
3 Jan 2006
Hello all
just purchased a raptor drive for my o/s. Im having trouble installing windows. I get to the stage were windows is about to install then get the message saying no hard drive found. any ideas
When you say you installed the drivers did you press F6 at the start of the windows install then 'S' when prompted later?
If you did the above are you sure the drive is connected to the SATA controller which you supplied the drivers for? What board are you using?
