Help with setting up WC solution
Just cleaned it now. Default speed around 600 rpm i think. I don't control them directly.
HA! never thought of reversing the HDDs so cables are out the way good one !
Will remove top and side see how it sounds :)
Edit: Was just about to order 1070 FTW2 when realised 1080 FTW2 is about 90 quid more but comes with Destiny 2 which i was going to buy anyway ... :) So guess what i just purchased :P
Yeah overclock that CPU if you have not already done so, Pretty easy for the performance gains, What is your current temp of the CPU anyway under load/idle etc? Prob need some new paste.
So here is a little stress test on CPU and GPU. Sorry not very scientific but should provide insight no ?
Since you guy took the time to send opinions i took the time to actually list my complete PC.
Do you see something OFF about the whole config now with the new GPU ?
https://uk.************.com/list/fHGkNN
************ part list / Price breakdown by merchant
CPU: Intel - Core i5-4670K 3.4GHz Quad-Core Processor
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: MSI - Z97-GAMING 5 ATX LGA1150 Motherboard
Memory: Corsair - Vengeance Pro 8GB (2 x 4GB) DDR3-2133 Memory
Storage: Crucial - M4 512GB 2.5" Solid State Drive
Storage: Western Digital - Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive
Storage: Seagate - Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - GeForce GTX 1080 8GB FTW2 Gaming iCX Video Card
Case: Fractal Design - Define R4 (Black Pearl) ATX Mid Tower Case
Power Supply: Antec - TruePower New 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
Wireless Network Adapter: TP-Link - TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter
Monitor: BenQ - GL2450HM 24.0" 1920x1080 60Hz Monitor
Overclock your CPU !!!!
It's running at 3.6ghz and you could chuck a cheap AIO watercooler on it and 4.6ghz would not be unrealistic.
