hi all
Would appreciate any help. Having had some experience of Sony PSVR I was thinking of going for an oculus or the HTC but to do this need to buy a PC as well. I could go laptop but the hardware is more expensive than desktop.
If I go desktop do I have to buy a screen or can I connect the hdmi out on the graphics card to my LG Oled and use that as a primary monitor? I really don’t want a screen and this Pc will only be used for gaming.
Thanks for any advice.
Josh
PS. Is the experience with either of the above systems better than PSVR
Josh
overclockers sells laptops
