Help with SLI temps.
Nice job murah, I have x2 fans on the hdd cages like that, but there not the best for airflow. Replacing them with x2 SSAP 15's which should be better.
just get decent airflow going, if can add a side fan that can help, or a bracket that holds 2x 120mm fans like I have
That's how close my fans are already blowing air onto the gpu. I won't be getting a side fan install as it will nit look to great.
I tried all that when mine was close and nothing helped. The GPUs are so close its hard to get the bottom GPU hot air away fast enough.
That's why moving the more apart is the only real option. If you ever fig away by keeping them that close and getting bottom GPU hot air away fast enough so that both GPUs are running close to single card temps.
Do share :D
This is my temps, before top GPU would hit 90c
Normally hitting 79c on my top card, but today I stuck x2 air penetrator fans on the hdd cages, max of 72c tonight in game. Can only get better when I stick two of theese un 140mm size on the front intake spots. The column of air they push us very impressive.
