Help with SLI?
28 Jun 2012
Firstly i currently have Asus GTX 670 Direct CU II 2GB GDDR5, can i buy an EVGA FTW or do i need same card.
Next how do i set it all up? is it easy?
As in do i need HDMIs for Both Cards etc
You only have to pair the same card so two 670s.
What motherboard do you have?
I don't understand your last question. If you're gaming on one monitor then you only need to wire it up to one card. The connection between the two cards comes via the SLI bridge.
Just make sure that you get two cards with the same amount of memory. :)
Also what is the actual model of your motherboard? Some boards don't allow SLI.
