Hey guys, well it's time to make some space in my room so my Coolermaster ATC 4000sx is going to be retired and I am thinking of scaling down to a Sugo SG03.
My requirements are a quiet and cool pc for watching TV downloads, browsing, irc, mp3, photo editing and a bit of mame, I do not play pc based games so power graphics are not required however I do need duel dvi so I can run a dvi lead to my tv and also my monitor. For this I will probably buy a Matrox card as I like good quality 2d graphics. I notice ocuk no longer stock Matrox. I will however be purchasing all other parts from ocuk and have used them since at least 2000.
So far my spec list is as follows, please help me fill in the missing parts.
Again, cool and quiet with some power are my main considerations for this build.
Case: Sugo sg03
Mobo: Gigabyte GA-MA78GM-S2H
Proc : AMD Athlon x2 or Phenom, which runs cooler? budget £100
Cooler: NT06-E
Memory: DDR2 2gb. Good quality DDR2, any suggestions? budget £60
Graphics: Good 2d card, probably Matrox if it fits the case.
HD: Already have Sata drives
PSU: Suggestions for quietest and size? 400w should do it.
Optical: Will probably use external once i've installed os.
Additional fans or swap out stock fans for quieter performance?
Additional rubber gromits required anywhere in the build for damping noise?
Thanks for any suggestions guys... I have not done a build for a couple of years now so may be missing something.
Case: Sugo sg03
Cooler: NT06-E
