Help with speccing ram/Gpu
19 Jul 2013
derby
looking to order upgrades before the weekend but I don't know what to order
need 8 gig of ram for a start
currently got 4 1gig samsung PC3-10700 667Mhz
looking to spend around 60?
and I have a GTX460 that's just had its day now
can I get a worthwhile upgrade for around the 100 mark?
PC is used for gaming nothing crazy cs:go lol bf3
and whilst I have your attention in the next few months I want to get an SSD which is a good price:performance one too get?
Thanks in Advance
What's the rest of your spec?
YOUR BASKET
1 x Powercolor Radeon R9 270 TurboDUO 2048MB GDDR5 PCI-Express Graphics Card £125.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £49.99
Total : £185.58 (includes shipping : £8.00).
As for an SSD, this has just been released: (There's also a 128GB version, but 240-256GB is the current sweet spot).
YOUR BASKET
1 x Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) £79.99
Total : £88.69 (includes shipping : £7.25).
You might as well go for some 1600MHz ram as i doubt it will support 2400MHz. The Teamgroup black would be a good choice. Windows 7 64Bit will support 8GB+ depending on what version you have.
OS is home premium 64bit
i cant seem to find any information on my mobo. PC was originally a Dell jobby, but upgraded after a few years
screenie of Mobo in spoilers
Windows 7 64bit Home Premium allows up to 16GB Ram.
Have you tried overclocking your current i5 ? I don't know how good a Dell board would be for that but it might be worth a try first before spending on a new cpu/board.
You can get a cheap cooler for around the £20 mark.
Can you find out the make/model of the psu ? There should be a sticker on the side of it.
Hmm Powercool is not a good brand :( You would need to get a new psu before contemplating a new graphics card.
Something like this would be a good solid option. Does your case take a standard ATX size power supply (As below) ? I know that some of the mass produced pc's can have some non standard parts in them.
YOUR BASKET
1 x NZXT Hale Power 90+ 550W '80 Plus Gold' Power Supply £43.99
Total : £53.59 (includes shipping : £8.00).
it seems like my best option is to save abit more money and do a complete PC overhaul as everything seems to be abit dated
how much would you guys recommend to get a decent noticable upgrade? so I can figure out how much i need to put aside
If you want to upgrade the cpu/gpu/motherboard/ram/case then you are probably looking around £500
YOUR BASKET
1 x Sapphire Radeon R9 270X Vapor-X OC 2048MB GDDR5 PCI-Express Card £149.99
1 x Intel Core i5-4440 3.10GHz (Haswell) Socket LGA1150 Processor - Retail £131.99
1 x Gigabyte H97-HD3 Intel H97 (Socket 1150) DDR3 ATX Motherboard £74.99
1 x TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01) £55.99
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
Total : £511.36 (includes shipping : £17.85).
The build above wouldn't allow for overclocking due to the non 'k' cpu and H97 chipset.
You could also consider an AMD build as a slightly cheaper option.
YOUR BASKET
1 x AMD Piledriver FX-6 Six Core 6300 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £83.99
1 x Asus M5A97 EVO R2.0 AMD 970 (Socket AM3+) DDR3 Motherboard £74.99
Total : £457.36 (includes shipping : £17.85).
that's not too bad. wouldn't need the case got a coolermaster storm.
could I use my old graphics card for a short while and buy the rest now? and get a new card at a later date?
will these builds be upgradable in the future?
you could yes. The AMD build isn't very upgrade-able CPU wise. The Intel route may be more upgrade-able in the futute but, AMD is cheaper in the first place. I would go the AMD route and get the best graphics card that you can. a FX-6300 and a R9 280 is a great combination.
