hornetstinger said:
OR you could just clarify what you meant in the post Entai questioned.
Originally Posted by hornetstinger View Post
Frequency Response (-6dB - IEC 268-13)
28Hz - 100kHz
32Hz - 100kHz
hornetstinger said:
There you go. +/-6dB. So, sorry they don't play to those frequncies,
someone else more knowledge will be able to get proper figures (think half octave higher)
So my speakers with -/+ 2dB play much lower (and flatter)
"IEC 268-13 attempts to be representative of a domestic listening space, and specifies the room dimensions, reverberation time, and background noise levels"
hmm does that mean room gain is taken into consideration?
Entai, hornetstinger means that if you were to use the standard +/-3db measurements, the quoted range on those speakers would be something like half an octave higher at the bottom end.
For anybody that doesnt know (and you dont need to be a knob if you do), a speakers frequency response will naturally tail off at either end of the spectrum. That quoted xDB figure is the point where the response is xDB away from the average across the range. so:
Code:
28Hz - 100kHz
This means that, at 28hz, the response is 6db down from the average. Which is a fair whack. If you were to use 3db instead, that 28hz figure could easily increase to 35hz or somewhere around there which is roughly half an octave which is what hornetstinger was trying to convey. Albeit badly.
and what's with all the speaker willy waving ? It's embarrassing to read.
nightrider1470, if you're still reading this thread, it's been hinted at a few times but lost in the nonsense above but generally do the following and you wont go far wrong:
turn the sub crossover off or set it as high as possible
set the sub volume control to 50%
run the subs own correction first.
Then run the Amp's.
Running the sub's own correction first will take car of most of the grunt work in try to get the subs response as flat as possible. Not just the frequency response but phase alignment too (v. important). This should make it as easy as possible for the AV amp to integrate the sub with the rest of the speakers.
in regards to setting the crossover point on the av amp after setup is run; Most amps will default to 80hz yes, but not always. Its not a hard rule - it's a recommendation from THX - so don't be afraid to play around with it. You may well find that something lower works better for you. Or you might not
