Hi All,
I got a Abit IN9 32 Max, E4300 C2D and OCZ PC2 8500 2 Gig ram.
OC'ed the e4300 before I bought the OCZ ram. Now that I put the new ram, I got my CPU at 3gig and running it as 5:4 with my ram which gives my ram 1066Mhz which is the standard speed.
I set the Voltage of the ram to 2.3V and the CPU at 1.365V, ran Orthos for 5 hours it failed with a message saying Hardware Failure.
Is that hardware failure to do with the CPU ram setup or can it be some other hardware?
Is the set voltage good or do I need to change them?
Thanks
Thanks
