- 23 May 2005
- Auckland, New Zealand
Hey guys,
just bought my first road bike, coming from the mountain biking world.
Anyway, got my new bike home and started setting it up, tried to remove the rear wheel to remove the dork ring and I can't do it! The thru axle is stuck fast. I'm a little worried as it's a carbon frame and it's only supposed to be tightened to 11nm.. but it won't budge. I'm not used to thru-axles so not sure what the best approach here is. I've put a bit of lube on where it touches the frame incase it's fused or something and might try a hair dryer but anything else I should try?
Why would the shop have tightened it so much!?
Cheers!
Cheers!
