- 4 Nov 2005
I've had a torrid time fitting my Tuniq Tower. In the end I sheared off the head of one of the bolts. I was having difficulty screwing it in, and so used pliers
. I think the resaon must be that I have crossthreaded the back plate that goes under the motherboard. I see 2 options (other than chucking away the bl**dy thing):
* Fit normal nuts and bolts (bit industrial, not in theory should work).
* Find out if Sunbeam do replacement parts?
Any thoughts?
Thanks
. I think the resaon must be that I have crossthreaded the back plate that goes under the motherboard. I see 2 options (other than chucking away the bl**dy thing):* Fit normal nuts and bolts (bit industrial, not in theory should work).
Any thoughts?
Thanks
