- 30 Jul 2007
I am considering a raided storage solution using SATA hdds.
Considering 7 disks + 1 parity RAID 5. (start with 2TB HDDs, but dont want to be constrained from upgrading HDD sizes).
Ideally want raid controlled by hardware not os (for robustness/flexibility rather than speed)
I am trying to work out if i build my own (own case, own controller, own pc) whether it offers better value for money.
I dont need stellar performance, just something approaching the native read/write speed of the disk (ie dont want NAS/ to access over a gbit network).
So i am considering an external esta connected storage chasis or just a BYO PC.
Qu 1. Do controllesr with SFF-8087 connectors like Supermicro AOC-SASLP-MV8, 8-Port SAS/SATA Card. mean that four HDD are sharing the sata III port bandwidth? IE its more important to buy a controller with 6gbps support.
Qu 2. "4/5 port" controllers with 4/5 physical ports eg. startech or highpoint or lian-li are a better price point than say a 8 port lsi controller. i presume 2 x 4port controllers can not be bonded (at hardware level) to support a RAID over 8 hdds?...
That said two "4 HDDs+1 parity" bundles using a lian li 5 port sata, might be more cost effective (True 8 physical port controllers are much more expensive, if the supermicro above wont work).
Qu 3. Is it the case that the these types of controllers cards (like the startech/highpoints,supermicros) will not have the type of max hdd size constraints that some prebuilt chassis have?
Qu 4. IS a SAS/SATA controller any less good than a pure SATA controller for my requirement? do i need to worry that it is a SAS controller as well. (i wont use SAS?)
thanks
thanks
