Help with using water cooler a on MSI B75IA E33 Motherboard
6 Nov 2018
I'm half way threw my first pc build
Specs/Parts I have!
I7 3770 NON K
MSI B75IA E33
2x 4Gbs Corsair Vengence 1600mhz (Blue)
Bitfenix Phenom itx Case (White)
Aerocool Integrated MX500w Semi-M PSU
Parts On Way (That I have questions about)
Bitfenix 230mm spectre pro white (Blue LED) Will be front intake!
Coolermaster Seidon 240m AIO, Will be top exhaust!
My problem is I only have 1 4 pin CPU fan header and 1 3 pin SYSTEM fan header!
Can I connect my Bitfenix 230mm to my only system fan header, which is a 3 pin?
Will my 3 pin SYSTEM header (Ramp up and down) the attached fan as needed?
Regarding attaching my 240m seidon (as top exhaust)
This AIO has 2x 120mm fans and a pump to power.
How do i attach the seidons 2x 120mm fans threw one cpu fan header (whilst having both fans ramp up and down) in accordance with my only 4 pin CPU fan header's requests.
Lastly and most concerning How do i power the pump (from the MB) and keep the pump safety cut of warning!
As I've said I'm waiting on arrival of seidon240m and bitfenix 230mm pro fan. I will upload pics of system build and MB as they're is a fee connection around CPU that the manufacturer's hand book doesn't go in to. Any advice on what these are for would be great, I'm new to this and may be missing an obvious Pump header or something?
Hope someone can help!
Can't work out how to post pics? Is that possible?
