helppppp
i recently got a new vista laptop to use with my xp pc.
I was on a direct cable modem with virgin for my net and now i use my old router to set up a network so that i can use both system on the net at the same time
i have come upon a snag with the laptop
with everything normal and plugged in as standard.. and vista at service pack 1
I can;t get on the net.
in the network and sharing center there is a red cross between the network and internet icons
i have access to local only and connection of local area connection
when i click on the red cross i get
there may be a problem with your domain namer server (dns) configuration
i tried to fix it by setting the dns manually on tcp/ipv4
i tried disabling tcp/ipv6
i tried pinging my router which works but pinging anything else wouldn;t
my local area connection status shows that data is both transmitted and received
please help
please help
