Help with VMWare Datastore issue
Hi mate, I've been working with ESXi for years so hopefully can help you out a bit here. From what I can gather you have a server with 2 hard disks installed. These hard disks each have one virtual disk stored on them. These virtual disks can be set to a larger size than the underlying physical disk if they are set to thin provisioned. this allows for overallocating the storage but can cause problems if the actual data size gets near to the underlying physical disk size as this is a hard limit. Windows (or whatever OS you have installed) cannot see the physical disk and believes that it has however much space you have said is the size of the virtual disk which appears to be what has happened here. If the virtual disk files still exist then potentially you can get the data out of them. First off enable TSM-SSH on the ESXi host and then open an SSH session to your ESXi host. Once connected run ls /vmfs/volumes which will show you the volumes you have on your machine. there should be 2 volumes that match your datastore names (from what I can tell these are Please Media Storage and datastore1). Can yoiu please run ls -l on each of these (ls -l /vmfs/volumes/datastore1 and ls -l "/vmfs/volumes/Please Media Storage") and post the results here then I can get an idea as what you have currently. What may be the safest thing would be to manually create the Plex Media volume using command line and get it to fiull the physical disk, this way when it is running out of space this will be visibil in the guest OS as well. Note: as this is a Linux based OS everything is case sensitive so bear that in mind.
Cheers
Hi Chris, thanks for replying.
So, a couple of updates since my last message. Unfortunately the 4TB has since failed. I dont think this was the problem all along, just sheer bad luck.
Whilst I still have it up and running on the main 500GB drive, im planning on changing things up during/after Christmas as 500GB simply isn't much to play with for what I want.
As easy as it would be to simple populate a NAS with a couple of large drives, it would be a shame todisgard the Proliant given that its in good working order.
Therefore, couple of plans im thinking of:
Plan A:
Clone the existing 500GB boot drive on to a new 500GB SSD
Purchase 2 x 4TB SSD and go RAID0 again on the basis that SSD should provide a little bit more reliability. In time, I could then purchase a 3rd and 4th.
Plan A:
Purchase 1 x 4TB SSD and and then a single 4tb external hard drive to use as a back up solution.
Plan C:
Purchase 2 x 8TB SATA and implement RAID1 so that if a disk was to fail, I wouldn't have to start all over again. No backup
Plan C:
Purchase 1 x 8TB SATA and 1 x 8TB external hard drive. Create a single W10 machine with 8TB capacity and then configure the backup to go to the 8TB external drive. In the event the internal 8TB was to fail, I can utilise VMware to create a new vm and then migrate my media back over
All the while im typing this im not really thinking of what could happen the main 500GB SSD with VMware, therefore, im all ears as to additional "plans".
Basically I want maximum storage for as little cost as possible. The only reason im thinking of SSD was that they might or should be less prone to failure. Not sure if they would add to Plex performance, but happy to be corrected on that front.
Plan Z
Forget about any kind of raid, clone your SSD to a new one, and buy 2 new hard drives.
Use one of them, and get a USB caddy for the other one.
Plug it in once a month or whatever and backup to it
(Also backup the VMware virtual machine if it's that hard to recreate)
Sorry - for some reason had missed the earlier reply you updated.
As above, I would be concerned about using any RAID0 setup. If they are new drives, yes it might be reliable if they are new. But at the same time I think that is striping across both disks, meaning if either fails then you'll lose your data (as far as i'm aware, not done any hands on for a while)
From your latest update... if you are wanting the max amount of storage for cheapest cost, then just go with a single large disk and set it up link you have listed on PlanC.
But also as suggested from Armageus, need to consider backups if then relying on a single drive.
To be honest as it sounds like you are pretty much having to start from scratch here I would go with Begbie's suggestion of installing unraid. I have this configured on a Microserver and it is really easy. As you just have media you dont really need SSD speeds (unless you are planning on streaming loads of stuff concurrently) so you would probably be better getting a couple of spinning disks. Within unraid you can add up to 2 parity disks so if you got 2 disks you can have one to store your plex stuff and have the other disk as parity to give you some resilience (this doesn't negate the requirement for having a backup though) You will lose the capacity of one disk if you go down this route, however you can add disks later on to increase your capacity and add another parity drive if so inclined. The only rle to be aware of here is that the largest disk(s) need to be the parity disk so maybe take this into account, but you don't need to have identical disks making up your array which is recommended for standard RAID. As Begbie also advised you can run VMs within unraid so you can have this running from your server with the folders mounted as SMB or NFS to be able to download stuff straight through. Bear in mind as well that your ESXi is quite out of date and it has got a lot harder to get hold of the install media if you don't have a license since Broadcom bought them out. You can no longer get the free ESXi that people used to use for running home servers
Hi Guys, Happy Christmas.
So, like a little Elf ive been working away on the above and I decided to go with Unraid. Ive also decided to move away from Plex and I picked up a Zidoo Z9X 8K and its phenomenal.
Unraid is working like a dream. Whilst it took me a while to get operational, more from a internal networking issue, its very nice to use.
In the end I went with a new 12TB drive, I stuck in the old 500GB drive, and for now, I have a 128GB SSD, soon to be replaced with a 500GB SSD which is acting as a cache drive.
Really like how you can add additional drives as and when. I'll probably add a second 12TB in the next few months, but even with the 12TB drive installed, that should allow for a minimum 250 4k movies - 24TB in totally will probably be over kill.
Thanks for the recommendation, and thank you in general guys, very much appreciated.
It may be a little late now, but if you are wanting to move stuff from your 500 GB drive to the 12 TB then look at the unbalanced plugin (install from Community applications). This will make moving stuff around between your disks in Unraid really easy
Hi folks, happy new year.
I see it's nearly a year since I was last here. That's obviously a good sign in that all has been working well with all the help you gave above ref UNRAID.
The reason for coming back in today is that I really need to start thinking of backing up the single 12TB drive I have as my main media server.
As it stands, Ive used 7.78TB which equates to approx 270 movies. With the remaining 4.22TB, that's going to get me another 70-80 movies at minimum, meaning an overall 12TB datastore should allow for a media library of 350 give or take. Whilst im happy with that, im thinking of two possible upgrade plans that I could do with some help.
Option 1: Pick up a second 12TB drive, either internal or external, but for the purpose of backup. Ive put in an awful lot of work over the past 12months and to loose 7TB+ of data at this point would be catastrophic (although life would certainly go on).
Option 2 (somewhat preferred, albeit more expensive): An expected movie library of 350 is appealing, however, long term, I would prefer double that amount. I can't really see me needing room for any more than 700 movies unless I start to upload just any old thing, however, never say never. Therefore, having a datastore of either 24TB or 36TB is what im thinking. But in terms of backup, would it be better to set my limit at 24TB and make use of a 20tb external hard drive for backups, or implement RAID 5 with the aim of having a 1 disk fault tolerance setup?
What's more likely to happen, to a) randomly loose all my data, or b) for a drive to fail that I could simply replace and simply rebuild the RAID.
All input and better suggestions most welcome. Also need to take into consideration my current setup. Part of me is thinking that even if I had an additional 2 x 12TB drive, building a RAID5 across 3 drives would be impossible without erasing all my work. Maybe even go for an additional 12TB drive and implement RAID1 mirror, and down the line, do the same again with another 2 drives - could UNRAID cater for that?
Apologies, my minds wandering at this point.
Option 1 with an external drive is the only option that gives you an actual backup of the data.
If you go with expanding your storage into a RAID array (or some other pooled storage solution) that gives you some resilience against the single point of failure (your current drive), but it doesn't give you a backup of your data.
Rather than go external, could I do this via UnRaid? For example, my server can take 4 drives altogether, so if I went with an additional 12TB for now, I was thinking I could install it in the server and if UnRaid has the capability, set the new drive as a backup source for the original disc? My thinking behind this is that UnRaid would allow me to monitor the performance of the backup disc, where as going externally, I have no way of knowing if the drive isn’t performing optimally.
I could then repeat this down the line as and when I pick up an additional 2 drives.
There would more than likely be something that lets you replicate the data between internal (or external/remote) drives either in real time or on a schedule.
You have to think about what you actually want from your backup. If your only backup is in the same physical computer, always online, and always replicating from the source disk then there is a high chance that should a disaster strike it's going to affect both copies of the data.
If you want an actual backup, then you would want it offline and physically away from the original version of your data.
Ok, so I think it’s best I go with an actual detached backup drive. Question now is, once connected to my HP ML10, what software should I use, and how do I go about scheduling this. Can I all this via UnRaid?
I’m going to start taking a nosey on the UnRaid dashboard over the coming days.
