Help with water cooling!
25 Jul 2013
Okay, some sometime next year im looking in builkding my first water cooling loop inside the corsair 900d.
I have put together a parts list and i would like to know peoples opinions on wether it would work or not :P
XSPC EX480 480mm Quad Fan Radiator
XSPC Acrylic Dual 5.25” Reservoir for Laing D5
3/8" ID (1/2" OD) Masterkleer Clear Hose Per Metre
Feser 1/4" Thread Compression Fitting for 3/8" ID - 1/2" OD Tubing : Silver X10
EK Water Blocks EK-Ekoolant Premixed UV Blue - 1000ml
Corsair SP120 Performance Edition Case Fan X4
Alphacool NexXxoS XP³ Light Plexi Edition - Intel/AMD
Watercool Heatkiller GPU-X³ GTX 670 X2
£80 at overlockersuk but x2 so £160
http://www.overclockers.co.uk/showp...id=WC-017-WC&gclid=CP3ckN_ByrgCFXHMtAodC1MAcg
Also i have drawn a little diagram thing on how i want ut to look :P
(excuse the expertese drawing skills!)
