help with water cooling
28 Oct 2014
hey guys so heres my setup and the water cooling parts i was thinking of using advice would be much appreciated and what case to go for .....
Intel Core i7-5960X 3.0GHz 8-Core Processor
£761.00
Asus RAMPAGE V EXTREME EATX LGA2011-3 Motherboard
£327.70
G.Skill Ripjaws 4 series 16GB (4 x 4GB) DDR4-2400 Memory
storage Crucial MX100 512GB 2.5" SSD £149.98
Toshiba 2TB 3.5" 7200RPM £49.01
EVGA GeForce GTX 980 4GB Superclocked Video Card (2-Way SLI)
£464.99
£464.99
EVGA SuperNOVA P2 1600W 80+ Platinum Certified Fully-Modular ATX Power
LG GH24NSB0 DVD/CD Writer
£14.89
water cooling i was thinking off .... ek cpu water block... ek gpu waterblock... EK X3 Multi-option Reservoir x 2...... AlphaCool D5 Pump with HF Top x2 ..... AlphaCool XT45 480mm Radiator x1 ............ AlphaCool XT45 560mm Radiator x1 then the fittings..., not sure on case
Get a 900D and some fat 1/2" fittings/tube. You're going big with the specs so go big with the rest :).
To be fair I don't know of any cases that can fit a 560mm 480mm is the biggest I've seen in the uk. I think caselabs do some that can take it but you're looking at a rather expensive delivery let alone the case.
Why not just go with 2x480mm and a 900D. More than enough rad space and room in the case.
