Help with watercooling setup!
Lay it out like this using the pump/bay res i linked you to?
Edit:Re sized image.
here you go: this is what i have at the mo but WITHOUT all of the watercooling gear, this is wear i will mount all of the w/c stuff :) but not sure where to route tubes but i will figure it out :)
i am currently looking at pump/res all in ones and have a question :p do i need to take apart a pump to install into the bay res or does it come with one pre-installed, also how hard would this be because i have noticed this on ocuk: XSPC Dual 750 Bay Reservoir & Pump - Clear that has a pump built into the bay/res and seems more of a plug and play component? any ideas on this?
Use compression fittings easier to use. look better, just as safe as barbs + clips. if there good enough for rjkoneill there good enough for use. I use a XSPC Res/Pump 750 in my loop no probs at all, use distilled water + silver coil, See Sig.
thanks for the info!, do you know anywhere i can get my hands on a silver coil trust me if you know please!
thanks again!
