- 11 Dec 2024
- Manchester
Hi
I have just bought a wifi repeater (Netboost Pro) to see if it will help with an intermittent connection dropping issue. My router is in a bedroom upstairs. I have plugged in the wifi repeater near the router on the landing of the house. It has created another network in the same name as my router but with EXT at the end. If I join my devices to that EXT network the speed drops dramatically. The wifi light on the repeater should I think be solid green which it is but it does flicker as well. As you can probably tell I am not very technical so any help anyone can give would be appreciated.
