- 23 Sep 2008
I have the sapphire toxic 4850 512,b, want to crossfire it up. Do i need an indentical card? I know you do for sli, but was told that for xfire you can use different ones as long as the are the same series.
I want to get the powercolour with the custom cooler as its cheaper and i know i could OC the GPU to the same speed as the toxic.
Thanks.
Thanks.
