help with xp setup
22 Apr 2006
london southwest
I have a abit lg 81 with p4 531
ddr2 533
boot window xp cd no problem.
then there is a message (set up inspecting your hardware configration)
after that i got blank sceen. forever.................
i tried took all usb stuff off. reset bios. nothing works.
any ideas please....
you may also want to check your bios, just to make sure everything's being detected properly.
Could be anything really. If its not the CD try it with one stick of RAM installed and the bare minumum, i.e. no PCI cards installed. Check that the CPU isn't overheating also.
