Weak at that price and it doesn't even have Thunderbolt.
Hardly
As for Thunderbolt, whys that important?
The UP7 is the best.
He has the one with Thunderbolt. Gigabyte Z77X-UP5 TH
Why not, if it's their flagship. At £320 I want all bells and whistles. Sure it sounds greedy but it's still £320. It's supposed to be the best. Don't say best but things are missing.
There boards are the best for overclocking. End of!!! I cant comment on warranty as I dont return product.
IC3 are you any place to advise on high end rig when you don't own one yourself???
I just love when fanboys come on forums and say that what they own is the best even though its not the best...
Asus yes good quality but the warranty is terriable, my mate had to wait 2 months for his sabertooth x79...and after that time they send him same board with same issue... than after 3 months he got a new one and sold it.
If mine breaks, Im not gone bother to send it on warranty just buy a different board...
That UP7 is the best overclocker. Currently theres a world record broken on that board.
By the way money is not going to give you knowledge about products...
Especially if you are a fanboy...
moving from what youve got to what your talking about getting is a bit of a side step.
I wouldnt think you would notice much difference to be honest mate the machine you have is already epic
you might be right, the more I think about moving to a new chipset, the more I think I should just stick with what I got, it's rock solid stable atm. Just unhappy with my SSDs at the mo. I got an 840 and vertex 4 and they're both plugged in to the sata 3 coz the marvell is ****e to say the least.
The marvell is a pile of *****
I had that board before the R4E im on just now and I remembered feeling alittle ****ed because I had a mega top end board that says its sata 3 but its not.
Only on benchmarks will you notice the difference between your 840 plugged into a sata 2 port or a sata 3 but I know the urge to upgrade is strong. I got my R4E in january and its still the best board out there imo. just a thought why not get a R4E and a 3930x and change the cpu to a ivybridge extreme when there out? Having a 980x already this is really your only worth while cost effective upgrade path?
Interesting point there. What mem do you recommend 24GB kits or better and can I use my tripple channel 1800 G.skill kit from my R3E on the R4E?
You can use the memory you have on the R4E but that wouldnt make use of the boards quad channel ability unless you got some more of the same. I use 4 sticks of corsair dominator giving me 16gb but a lot of people have said how good the 32nm samsung stuff is. Again its only a suggestion but if it were me id put chip board and ram on ebay and change those because if your going to change board and chip then ram is nothing really at todays prices.
You should be able to get £350-£400 for your stuff on the bay so its not a mega costly upgrade. this will give you a great upgrade path and sata 3 plus faster ram and chip
