Help would be appreciated.
31 Dec 2011
Hi,
I am hoping for some suggestions from someone with more PC building experience than I have.
The rig I have at the moment is about 5 years old and is starting to struggle with the newer games.
It comprises of an E6600 processor, 4GB GeIL Value ram, Corsair 620W PSU, GTX 8800 OC graphics card, Asus P5Q M/B and it’s housed in a Lian Li P-60 Mid Tower.
Now I’m looking at the following:-
Processor – Core i7-2700k 3.50GHz (Sandybridge)
M/B – Asrock Z68 Extreme4 Gen3 Socket 1155
Ram – Corsair Vengeance 8GB DDR3
GPU – Gigabyte ATI Radeon HD 6970 2048 MB
I’m taking it my PSU is OK.
Now the problem is, I’ve read that the 6970 is 31cm long and as my 8800 just clears the HDD caddy I cannot see the 6870 fitting in.
Has anyone fitted one of these and if so what case were they using.
Thanks.
if its just for gaming then change the processor to an i5 2500k, because you get no benefit from the 2600k or 2700k in gaming.
also, you might want to go for some RAM with smaller heatsinks such as the kingston 8GB grey stuff, that way it wont clash with an aftermarket cooler
as for the case, is it possible for you to remove the HDD cage and still have space left for some HDDs?
the PSU should be perfectly fine for a single 6970
Thanks for the advice, Reaper.
Regarding the i5, is it suitable for video work as well as gaming?
I’ll take on board reference the ram; I could well have dropped a clanger there!
The HDD cage I shall have to have a closer look at. If I remove the cage I will have nowhere to locate my two HDD’s. I may be able to trim off some of the material to make room but if not, I feel it will a new case.
You are right, someone dishing out duff gen!!
As my upgrade won't be for a couple of weeks, I will be interested to see how the 79xx series shape up performance and price wise.
thanks for the info.
