My new set up is arriving tomorrow and im using my old hard drive with it. BUT my HDD doesnt seem to be working!
This is what happened, the HDD was basically partitioned into 3, it was my master drive, since my mobo broke i moved the HDD to the other pc and it was used as a slave.
I backed up my stuff and decided to merge all the partitions and format it ready for 2mo. However with partition magic when it reboots to make the changes it says it cannot find a certain thing and boots to windows with no changed.
i tried to use the HDD as master and install windows on it, windows setup formats it and then after the reboot it says there is a certain file missing and wont continue with the set up :S
any clues?
any clues?
