Help
10 Oct 2006
Hi, I took a screenshot of WoW, when i tried pasting the screenshot on paint it gives me this message?
you do realise screenshots get saved to the wow folder anyway? although they're saved as tga's so you'll probably need to convert em.
I have 2GB ram, I don't think not having enough ram is an issue. What program do you recommend to convert tga files? And this not only happen when I take ss of WoW, it happens to when I take ss off other games.
Im pretty sure you can open/import them in photoshop and then export them to a different format, e.g. BMP, JPEG
