Help
19 Jan 2005
My mates OS has stopped recognisin his cd drive, I checked it and the BIOS has it as secondary master but in device manager in XP it has a little exclamation mark next to it. He swapped the cables round but no result. I was gonna try puttin it in mine to see if it works in there but he tried a virtual drive with daemon tools and it says it with that as well so I'm assumin it isnt his drive.
The drive powers on and you can open it and things so that isnt it, tried updatin driver but nothin found. I suggested updatin the firmware but I'm not clear on how you do that so I wondered if there was a setting or somethin I had missed.
Any help I would really apprecriate. Cheers.
If you right click on the CD in device manager & pick properties it should give you a bit more detail on why the exclaimation mark is there.
it says windows cannot load the device driver, the driver may be corrupt or missing.
He got the firmware for it and tried to install that but it couldnt find the device to install it to.
