HELP
13 Nov 2006
Inverkip
I set about building my new rig today, got everything sat in place and fired her up, then nothing, well not what I expected anyway.
I get a little green light on my board, the fans kick in, the GPU kicks in, the light on my Fatal1ty kicks in but it refuses to post. My monitor keeps telling me to check my cables. Does anyone know what might be wrong? I'm thinking CPU, motherboard or GPU. I've tried the GPU in both slots to no avail, I'd welcome any help on this.
Need to know your specs really, but it sounds like your 3dcard.
Your sig's filesize is above the maximum allowed 20KB by the way.
May be a silly question, and going without your specs, have you made sure that you've plugged in the 4-pin power supply to the graphics card? I've lost count of the number of times I've forgotten to do that.
DVI cable was tightened up pretty well. I'm at a total loss over this. Everything seems to power up but I get no beeps from the motherboard and the bios screen won't post. There seems to be no signal going to the monitor.
Tried without GPU, no beeps. Took out the CPU and powered up, no beeps. Motherboard is being RMA'd to OcUK tomorrow and I look forward to another board and fingers crossed, problem over. My new Samsung 206BW is in serious need of some shiny Vista loveliness.
I've tried taking out the GPU, no beep. I took out the ram, no beep. I took it apart for shipping back to OcUk so I tried it without the CPU, no beep. When everything was in place and I tried to boot up, there would be no beep and this is what pointed me to the mobo as the main culprit.
Hi
Have you tried turning round the mobo connetion pins to the case front?
When I changed my mobo I found that the 2 pin connection had to be switched round in order to get it to work if you see what I mean
PWR was facing upwards as was the other pins then had to face downward to work even though the new M/B was the same way round.
If you're using an aftermarket cooler make sure it's not tightened too tight.
They can short the board if they are.
Could it be a PSU issue? - For some MB's no beeps often indicates a problem with the PSU... just a stab in the dark since all other options seem to have been exhausted!?
