HELP
26 Sep 2007
Essex, England
Ok, problem after problem for me.
My pc wont stop randomly rebooting.
Specs :
2gb ocz ddr2 800mhz
amd x2 5200+ @ 2.6
albatron 7950gt 512mb
abit kn9 sli
Basically, its rebooting at random times. When im playing call of duty 2, when im browsing the overclocker forums, talking to people on msn. Anything.
At first I thought my graphics card had broken, because my pc rebooted and I got a message 'out of range', which I believe is to do with the resolution being set too high, but in both nvidia control panel + desktop the resolution is set at 75mhz, which my monitor supports.
what could be the problem?
hey cob
im pretty sure the memory is set to 1.8v, but im not sure as i cant actually get into the bios anymore...
i just reset the cmos, reset the battery, reset all power cables and reseated the ram and now im not even displaying anything on my monitor
I would recheck all cables and re-seat the graphics card to see if you can get the screen back.
my psu is a 500 watt enermax liberty, so it is up to scratch.
il reset the graphics card again now and update you. i dont know i cant see the screen...
update : i dont get it. everything was visible before i reset it. also, im not sure if its a problem or not but i dont have anything plugged into the pci-e slots, but there is a 6 pin connector in the back of the graphics card
Does the machine spin up?
Try it with the hard and optical drives disconnected?
the machine spins up and sounds like its working fine
update : i took the hard drive and optical drives out, and it still spins up and sounds like its working fine
