Help!
19 Jul 2004
Afternoon all, my new system has just arrived.
I have a corsair 620 PSU
4GB geil
Q600
8800 GTX
Ip35 mobo
I cannot get it to boot!
I have stripped it all back to CPU and mobo with 1 stick of mem, it comes on all fans start going then shuts off after about 7 seconds then comes on and stays on with no display....
Any ideas?
Take out the RAM. Make sure the PC speaker is connected. Does it beep at you?
The On - Off -On seems to be characteristic of some Abit motherboards, mine does it too.
have you plugged in all the connecters including power ones to the gfx and the small extra power connectror to the mobo
Yea i have plugged in 2 PCI e connecters into the GTX and one 24 pin connector to the mobo and a further 8 pin connector next to the cpu (feeds the CPU i believe)?
there is also a ATX connector above the PCI slots does this need to be connected as well? i have tried with and without with no diff just wondered...
Cheers for your help, after the machine goes down after first turned on as the abits seem to do, i assumed it was shorting and unplugged everything inculding monitor...
After reading the above - i forgot to plug the monitor back in!
Plugged it in and after it boots for the 2nd time VOLA!
Cheers Guys
BTW Crysis in 64Vista is Gorgeous!
