HELP!!!
PSU is overpowered, you could drop down to a Corsair 620W, for less noise.
You'll definately want to go to 6GB, even if it means cuttting corners elsewhere. It'll make an enormous difference.
The watercooling setup looks ok, although it's not the best performing parts.
Right, i'm a complete noob at this so any advise would be greatly appreciated
Sorry but a noob shouldn't be spending so much on hardware for self assembly...
What is the PC for, what size screen will you be using?
Does it need to be silent, or just quiet?
AD
when i said noob i meant i am noob at water cooling as this will be my first attempt at it so any suggestions of what needs changing there is greatly appreciated.
it will be used for everything mostly gaming and photography though.
the screens that will be used with it is 2 x 19", 1 x 22" widescreen and most likely my 37" HDTV when watching movies etc.
