HELP
16 Feb 2007
Stafford, UK
Hi what does 'check signal cable' meen if ive just built my computer and the monitor doesnt work, i have tried 3 monitors and all say the same thing what have i failed to plug in (inside the pc) not the ones on the back of the pc or the monitor :D
Thanks need help asap
Thanks again
Na ive used 2 different cables and this the the spec
Abit IP43 Intel P43 (Socket 775) PCI-Express DDR2 Motherboard
Intel Pentium Dual-Core E5200 "LGA775 Core 2" 2.50GHz (800FSB)
Seagate Barracuda 7200.11 320GB SATA-II 16MB Cache - OEM
Sapphire ATI Radeon HD 3450 Silence 512MB DDR2 TV-Out/DVI/HDMI (PCI-Express) - Retail
Corsair 2GB DDR2 XMS2-6400C5 TwinX (2x1GB)
Thanks :D
tried 1 stick of RAM?
if it boots go into *** bios and set the RAM voltage to 2.0V turn it off then replace the other stick and turn it back on
No it says 'analogue then digital then analogue and digital' like flashing on and off then it goes back to the 'check signal cable'
Explain pls im not this smart when it comes to computers i will understand the non abbreviation lol
thanks
ive tried another still the same problem :( what other things would suggest its a mobo problem becuase it turns on and the fans power up including the fan on the processor
Ok the keyboard and mouse and speakers dont light up does this confirm the mobo is the problem becuase ive changed the gfx card for another and still nothing.
thanks
