help
28 Jan 2011
i have 3 gd245hq acer monitors in eyefinity with the 6870
and some times theres like a line on the screen when i use my gun on games
and some times theres like a petrol colour in the shadows or when i walk past a wall
its not all the time buh i hav seen it a few times nw
thanks
going across all 3 screens?
if it's just 1 of them then switch the monitor sockets around and see if the line appears in the same possition on the monitor you have just replaced it with, maybe it's just 1 monitor at fault, if the line is going across all 3 then the fault lies in your Gcard and you need to send it back
i just tried it nw and the petrol colour is gone buh the line isnt and when i move windows around the screen they break a lil in the middle like into 2 parts its hard to explane
It could be a graphics driver issue, have you tried updating or rolling back to a previous version? If you've swapped the screens around to rule out a faulty screen, then drivers are probably the cause. It's also possible your graphics card is faulty, especially if it's tearing and artifacting just by pulling windows around the desktop.
Does this happen when the pc is busy with other tasks or just randomly? What's the spec of the rest of the pc?
the tearing happens all the time with windows buh only when i shoot in games and i have a amd 1090t
asus iv
850w psu
the 6870 has had a update and it was the same in both ver
il try reinstalling the drive for the monitors cus i did it when i got the 1st 1 buh havnt updated since then.
i down loaded the new acer edisplay mana and it says its out of date and to check for updates buh the link says its up to date and its the same version any1 eles using acer with this prob ???
if your system clock is the wrong date set then it will say your driver is out of date as will be the case when updating anything in your machine
