help
12 Apr 2011
Ok i brought 2 asus gtx 285 i fitted both on an p5nt delux motherboard device manager only see's one i tried the card in diffrent slots fan spins but no pic tried other card which pc picks up all three slots working then tried card that aint showing pic in another pc and worked straight away have reinstalled drivers etc but still no luck power is good 850watt ocz any ideas anyone?
Try one card in your PC at a time. If you have any previous drivers, uninstall them. Update your chipset drivers.
There may be a Jumper or switch of some sort on your motherboard to enable SLI. I remember having an SLI card which you had to switch around on mine.
Make sure you have connected the SLI bridge from the box.
Is your PSU upto the job? Need your full spec to help more bro.
Ok sorry bit off rush first post but what it is i brought 2 asus gtx 285 both the same cards for sli put both cards in on the blue slots put bridge on but pc only saw one card so i tryed all three slots with the card that the pc picked up on it's own no probs but when i put other card in pc does not pick it up even on it's own but when you put the card into another pc it gets detected i have latest chipset drivers etc
i have asus p5nt delux
q9550 quad
2 hard drives
corsiar h50
3 120mm fans
