Help!!!
HDD bay: 3.5" HDD (Sata hot swap) x 9 / 2.5" HDD x 2
Looks like only 3.5" drives fit as hot swap drives. You probably need a drive bay convertor of some sort. Or just use a cable from the PSU. My Lian Li v1000 does have slide in fixings which suit the drive tray for the 2.5" SSD or HDD so it can hot swap.
I use masking tape to mount SSDs, although not since I got my R3 case as it's able to mount them directly. They're so light that masking tape does the job just fine.
