help
23 Jan 2010
St helens
my 1st pc plugged into slot 1 on my modem, works as normal
my 2nd pc im trying to get connected is plugged into slot 2
but the 2nd pc wont connect, it cant find a connection? any ideas at all?
its something to do with settings im guessing as i swapped the 2 cables from the beack of each pc and the internet works on pc 1 with either ethernet cable connected
ok this is when i thought it was connected to the net but im guessing the nvidia thing is just using the explorer to display that? but then it shows sent and recived? either way it wont connect to any sites
Your IP address is in the Link-Local 169.254 range, which means that your computer has not been manually assigned an IP, and the router is not using DHCP or for some reason DHCP isn't working correctly to auto assign an IP address.
If you go into your network adapter properties you can manually assign the IPv4 address. I think the netgear vmdg280 uses 192.168.0.1 by default, so set your ip address to 192.168.0.2 with a mask of 255.255.255.0 and you should have connectivity.
Right click on the 'local area connection' and go to properties, in the properties there should be a list of items, one of which is 'Internet Protocol Version 4 (TCP/IPv4)', click that and then press properties.
In that you should get a window with where to enter the IP address, try 192.168.0.2 with the mask 255.255.255.0 and the gateway 192.168.0.1 and hopefully that should work.
use the same settings as that PC then, except rather than using 192.168.0.2 use 192.168.0.3, as each device needs a unique IP.
it seems the 1394 connection seems to be conflicking between the 2 pcs not allowing me to use the same settings for both pcs?
should the 1394 connection be enable or dissable?
the no connection pc is xp and working is win 7 , doesnt matter does it?
ok so heres the settings now
ip ad 192.168.0.4
sub mask 255.255.255.0
default 192.168.0.1
Preferred: 208.67.222.222
Alt: 208.67.220.220
and guess what, it wont work, this is in XP, if i install windows 7 will it make any differance
also i notice above he says "ivp4 " but it doesnt show this on xp it just shows
internet protocol (TCP/IP)
Maybe XP didn't have support for IPV6 therefore it just says TCP/IP.
Try and ping the default gateway..
Start>run>cmd>ping 192.168.0.1
if you can do that try ping 208.67.222.222
Reuest times out for both ips
ill install win 7 and then start again..
would 2 pci adaptors in each pc work instead? im sure theres some in my mums shed ? connect to net throw my main pc instead
If you can't ping your default gateway you can only normally connect within your network.
ping 192.168.0.2 (you said this was PC1) could see if this works.
You tried plugging into a different port on the router?
