Can you suggest me a motherboard that would work please around the 150 to 180 pound rangeNo thats an Intel motherboard.
Are you definitely sure because I will buy itYou need to be looking at this collection of motherboards from OcUK: https://www.overclockers.co.uk/pc-c...rds/am5-b650-ryzen-7000-series?sort=price_asc
They should all support the 7800X3D by now out of the box as far as I am aware
Watch some of the B650 videos on HUB:Are you definitely sure because I will buy it
Yea that motherboard is perfect thanks a lotWatch some of the B650 videos on HUB:
Zen 5 Ready AMD B650 Buying Guide, Top 5 Best B650 Boards
Thermal Grizzly: https://www.thermal-grizzly.com/en/kryosheet/s-tg-ksSupport us on Patreon: https://www.patreon.com/hardwareunboxedJoin us on Floatplane: htt...www.youtube.com
I'm doing my best to avoid XTX process tooWow they have gone down in price a lot! I don’t even want to look at XTX prices.
If you pick a board you like then you can check the QVL supported processors (and RAM too). I have heard good things about the motherboard Henry hoov3r has and I have the X670E version of it which supported the 7800x3d out of the box back in November.Are you definitely sure because I will buy it
