Help
1 Sep 2013
Seem to have a fault on a computer i recently built parts supplied by oc
Pcs worked fine for a week a put it together for a friends son
Symptoms the fans and rgb will start up for a second then shut off
Things ive trued
If i take the mother board out the case with the power supply connected and gpu it will boot up no issues using the the screw driver method shorting the 2 pins
Bought new case same issue
Taken known working power supply out of my pc same issue
Swapped my ram same issue
Swapped cpu same issue
Intermittently if i press and hold the start button it will boot up will not off a quick press ive been going round in circles on this
Im thinking its motherboard
