Hi-fi setup
4 Jul 2010
Nottingham
ive got a hi-fi set up that's about 8 years old give or take 2 years, and when i play Cd's on it, sometimes the Cd's get cut for a few seconds and when i see the display on the screen it shows the times for the CD going back or forward in one place but only happens for 2-3 seconds and is annoying because it happens randomly!
Sounds like tracking problems. Could be the laser lens is dirty. Is this whilst playing CD-R's or does it happen whilst playing original pressed discs too?
What CD player is it?
If it's one where you can see the laser lens then try giving it a clean, use some meths or isopropyl alcohol on a cotton bud and gently clean the lens.
Another problem it has is being able to read rewritable discs even though it says on it that it can read rewritable discs,. when i put them in they just don't work it...nothing happens.
