Corsair 300R case should work .. the hydro can mount on the top of the case
H110 does not have standard 140mm fan spacing of 15mm and will not fit. They use 20mm.
Ronin should not be able to fit a H110.
This is from my technical department,
I can confirm this will also take a H110 in the roof. Should be plenty of room as you can mount the fans between the roof and top panel if you need to as well.
YOUR BASKET
1 x BitFenix Ronin Tower Case - Black £69.95
Total : £80.45 (includes shipping : £8.75).
