No, but good luck and wish you a speedy recovery.Anyone on here had it done?
Steam deck for the hospital stay?
Wait how the NHS turn you down for hernia surgery where your stomach is on the wrong side of your diaphragm!?I haven't been accepted for it yet but fingers crossed, will cost me 7k going private if NHS turn me down!
Apparently they sometimes do if it is under 5cm, .mine is 4cm...Wait how the NHS turn you down for hernia surgery where your stomach is on the wrong side of your diaphragm!?
Not had it done but at one point thought it might be an option. I got the impression that it isn't a magic fix so hope your GP / consultant have discussed the pros and cons plus any alternatives (e.g. losing any excess weight) with you.Anyone on here had it done?
AIUI, it's when the top bit of your stomach slides up through the diaphragm, allowing acid to leak up the oesophagus. It's not that your whole stomach is in the wrong place.Wait how the NHS turn you down for hernia surgery where your stomach is on the wrong side of your diaphragm!?
Yesh I know its part of your stomach not alm of it same as its only part of your intestines not your whole intestines that have popped out in a normal hernia. Still doesn't change the point.Not had it done but at one point thought it might be an option. I got the impression that it isn't a magic fix so hope your GP / consultant have discussed the pros and cons plus any alternatives (e.g. losing any excess weight) with you.
I think it's a bit different to other hernias where a loop of intestine gets through a sheet of muscle. It's not the top bit of stomach sliding up that's the problem, it's that it causes the valve through the diaphragm to leak stomach acid (which is a miserable experience apart from the damage being done). If drugs (normally PPIs) are safe and effective at suppressing the acid production, and surgery isn't always a perfect repair for the valve then I can understand why surgery isn't offered as the first option.Yesh I know its part of your stomach not alm of it same as its only part of your intestines not your whole intestines that have popped out in a normal hernia. Still doesn't change the point.
A bit of your ogan is on the wrong side of the muscle seems like an nhs job. "Missble experience" being what we all pay to avoid.I think it's a bit different to other hernias where a loop of intestine gets through a sheet of muscle. It's not the top bit of stomach sliding up that's the problem, it's that it causes the valve through the diaphragm to leak stomach acid (which is a miserable experience apart from the damage being done). If drugs (normally PPIs) are safe and effective at suppressing the acid production, and surgery isn't always a perfect repair for the valve then I can understand why surgery isn't offered as the first option.
Seems ridiculous doesn't it.. Lets wait until the hole gets bigger......Apparently they sometimes do if it is under 5cm, .mine is 4cm...
Was it worth getting for you? How was recovery?Yes, in November 2017.
Anything specific you wish to know?
I seem to remember being told that they won’t normally refer anything under 5cm, regardless of misery.Hiatal sounds serious, surprised they won't do it on NHS?
I went to my GP about a small umbilical hernia this week and he was happy enough to refer it for surgery.
I see the NHS guidance is to fix umbilical hernias in adults, as it will cause problems eventually, but that hiatal ones don't necessarily need treatment.I seem to remember being told that they won’t normally refer anything under 5cm, regardless of misery.
With a mixed hernia, If the fundus is pinched then it can hold the lower oesophegal sphincter valve open causing reflux. You can also have the blood supply to part of your stomach cut off (strangulation) which feels like being stabbed or a heart attack. This can potentially be serious and require emergency surgery so the “wait and see” guidance confuses me a bit.I see the NHS guidance is to fix umbilical hernias in adults, as it will cause problems eventually, but that hiatal ones don't necessarily need treatment.
I could write a very long post about this but will save that for another time.Was it worth getting for you? How was recovery?
What were your symptoms?
Damn, that's basically the absolute worst-case scenario. I suspect my sister is going the same way based upon her symptoms.A number of tests and checks, including another attempt at having an endoscopy where they couldn’t even get the camera down and a CT scan, showed that my stomach was completely through my diaphragm and pressing against my heart, so ECG readings were showing that I was having a heart attack!
