Hiberfil.sys?
Caporegime
8 Nov 2008
I have just started to copy over my ssd data to my backup drive (hdd), and a short way into it I received the following message :
Where do I go from here? Skip?
clone it instead? should copy everything
im guessing at hibernation file system? idk,can skip it if you want aslong as your important data is copied over
cloning would also be bootable incase you needed a backup os
yh ive used it and works fine
just remember to set the source drive as your ssd and destination drive as hdd and should be fine,doesnt take long either,can always boot up from it if need be
Hmmm...started up the Data Migration software, and it auto select the 'source' disk as my Samsung ssd, which is fine. However, it looks like it expects you to use a Samsung ssd for your target disk? Everything is 'greyed out', so I can't select what drive to use for the destination, such as my hdd.
Yes, skip.
It's the hibernate file for if you send your system to hibernate and all your memory is written to it. It's going to be out of date if you copy it to another drive, and it gets remade as when you boot your system off the new drive.
can try macrium reflect its free,once cloned expand the partition to fillup the hdd
windows will let you expand the partition I think in drive manager
If you cloned it, then it litterally cloned the partition over. The rest of the space is still in a raw state which you can extend the current partition or create a new partition with disk management.
