High 24/7 overclock temps question
Woke up to an un-responsive system on the 7th, so hard reset and checked the event log and it was the same BSOD code.
I bumped the VCORE up by another click and it has been folding solidly, as stable as anything for the past couple of days, with a bit of gaming here and there as well. :)
124 is not always VCORE be aware on Sandy it may well be VCCSA on your board.
It seems to have solved the issue so far though :) If it happens again, I should perhaps try putting the VCORE back to what it was on before, and nudge up the VCCSA voltage?
Okay so I have been using the system fine for a week, folding for extended periods of time (up to 18 hours in one go), gaming, video/image editing, rendering and so on and everything has been fine and dandy.
Woke up this morning to a system which was off. Turned it back on and it had BSOD'd with the same error code (124) in the night.
What does VCCSA voltage do, and how much should I adjust it by? :)
