- 18 May 2010
- London
One thing I've noticed since I installed my Ryzen 1700 is the side of my case seems to be warmer than when my old 3570k was in.
Now I'm using an old 2008 Thermaltake Armour case, and I've since removed the side 250mm fan to accommodate a Noctua nh-d14.
I checked the main exhaust fan at the back and it doesn't seem to output much heat, so maybe if I replace this I might improve things some what.
Any recommendation for a good 120x120mm exhaust fan for shifting lots of heat? What about this one?
Would be nice to replace the missing 250mm side intake fan too but... I noticed you cant buy 250mm fans anymore. Plus it would have to be really thin as there isn't much clearance with the Noctua sitting behind it.
Also the top fan on the case website it says it's 90mm but OC's only have 92mm fans?
