Hey, Ive just installed an Asus Silent Knight II on my Asus P5E-Deluxe + Q6600 combo in the hopes of dropping my temps to do some decent OC'ing.
However, Im using Zalman Super thermal grease and My idle temp is like 45-50c...
Ive reseated it numerous times (reapplying thermal paste each time, and cleaning the surfaces with thermal remover stuff)
When I run prime 95 its hitting 65-70 at stock speeds
As ive never really done much with thermal compound Im pretty sure Im not applying it right?
Ive tried applying it to the cpu, then to the base of the fan instead, then a little bit thicker then a little bit thinner etc etc yet i still have **** temps.
Any ideas?
Any ideas?
